I install an internal drive, the recommended crucial 4tb.
Recognises and formats fine.
I start transferring files over LAN, works for a bit then drive dissappears.
If I physically remove the drive, and then replace it, it reappears. I do a reformat, start copying, same thing happens.
It is securely fitted in the bay. The second time I installed it I made double sure it was properly fitted all the way in.
My suspicion is that it is too hot and cuts out.
Even if it managed to not cut out, the heat generated in the bay is too much for a drive to last very long anyway.
I know these amps run hot, very hot.
If there was a way to have a extension cable away from inside the amp it would prolong the life of a drive, but it my case it just cuts out before I can finish copying files.
The USB option is only 32gb drives, leaving no choice but to buy a NAS.
I bought the 4tb drive just for this amp, and I can’t use it.
