Hi, further update.
I visited a local audio dealer today to try out some new speakers and they are a Rose dealer and we used his 150b for testing purposes. His RS150b has the latest software installed and I bought my network equipment with me to test, without any issues. (Usual issue with RoseConnect app hanging and needing to be restarted, but that’s a given)
Back at home, I have also plugged the wifi adaptor back in and tried connection over the wifi and get the same network connection issue. I therefore believe the network card has failed in my unit.
Therefore issues with Hifi Rose are:
- Network card failure 3 months after warranty expired
- Mechanical hum from toroidal transformer since very early on in ownership.
- Software full of bugs and beta tested by customers
- I have tried tho use the usb input to stream Qobuz from my MacBook and use the RS150b as a DAC only, but the usb input doesn’t appear to work either.
- Sound drop out when using TV as a source, particularly over HDMI but also over TOSlink.
In conclusion it’s a load of rubbish!
I won’t take the unit back to the supplying retailer, as it’s now out of warranty and I experienced very poor service from them and have terminated relations with them.
HiFi Rose please do the right thing let Henley take the unit back and refund my money.
Regards
