After playing Rose Tube in 30 - 60 minutes repeatedly an error occured on my RS150b screen. “Unable to play due to a temporary error. Please try again later” (In Dutch language). Is there an update for available?
If the same problem occurs even after restarting the power, please provide the Rose ID in Settings > System Information.
After restart the same problem continues. ID is 0C88D6.
Thanks for your reply.
We have updated the RoseTube app to your device. After restarting your device, Select Rose Store and update the RoseTube app (Ver. 5.9.09.61). Please check that the service is operating normally.
My Rose Tube version is now 5.9.07.60 shown as the latest version. The same problem occurs.
When you select the RoseTube app in the Rose Store on your device, isn’t it showing a new version update? I’ll check again tomorrow and get back to you.
Sorry, we’ve reapplied. Please check after updating the RoseTube app.
Update Rose Tube v 5.9.09.61 was succesfull. Emptied cache as well. Test updated version this weekend. If any problem reoccurs I’ll let you know.
Thank you for checking.
I look forward to hearing your test results.
This weekend I tested RoseTube again. There was only one hick when playing. The Rose streamer stopped for about half a minute but then continued on its own. This was not the case with the old version of RoseTube because that was immediately a permanent stop. So it seems that with the upgrade to the latest version of RoseTube, the problem has been solved. I think that the single hick must have been due to YouTube itself. Thanks for your support.
If you experience any additional inconveniences while using it, please leave a comment.
