Had an afternoon playing music videos and again it’s stopped working.” Couldn’t play due to a temporary error please try again later “
I’ve tried deleting and reinstalling app and rebooting unit. Any one else having problems?
RoseTube and YouTube are not exactly the same.
We developed RoseTube based on the API that YouTube publicly supports.
If YouTube makes any modifications or changes, RoseTube may not run smoothly.
In this case, you can resolve this by going to the Rose Store on your Rose device and reinstalling the RoseTube app.
If reinstalling Rosetube from the Rose Store does not resolve the issue, please check if the same symptom occurs when you factory reset your Rose device.
