Rose tube lock is set - what does this mean and how can I unlock it?
I am using the Rose RS 150b.
Thanks.
Thanks.
How to unlock
Rose Streamer > Rosetube > Setup > Rosetube lock > Rosetube lock > OFF
Once password is set for Rosetube lock, you need to enter password to turn it off.
If you forgot password, you need to reset the streamer.
(Rose streamer > Settings > System Settings > Factory Reset)
