Am trying to get Rose Connect to play a Qobuz playlist in order (next one down and so forth)…after software update (newest), the song finishes and randomly goes to a song on one of my other playlists in Qobuz or one of Qobuz’s playlists!! One of two things happen when I play with shuffle on and off…goes to next song on playlist (what I want) only ONE time and then back to shuffle behavior or it gets to end of song and stops. Sorry if anyone else has discussed this but I’m stumped. I have no behavior like this when I go to Qobuz on my pc…plays fine and in order as I want…any help is appreciated. Also no problem using BluOS on my bluenode. Problem SEEMS to be with Roseconnect/software
I have a Roseconnect account. Unit is a RS250 with latest software. Using Samsung android tablet to control streamer
Problem two: Wanting to save new song to an EXISTING playlist. I click on three dots, scroll down to add to playlist and it won’t show my playlists on Qobuz…just a blank page and do I want to create a playlist? If I go to PC, log into Qobuz Account, no problem adding new song to an existing playlist
I NEED HELP
Hello @agram4
I have forwarded your issue to the software team.
We will fix the issue after checking it.
My Hifi Rose retailer solved the problem going into: System - Audio Settings - song play options - play from here. He had to change the last setting from whatever it went to on firmware upgrade to “play from here” STILL NEED HELP SAVING NEW SONG TO EXISTING QOBUZ PLAYLIST. Do I have to go to Qobuz site on m,my pc to add new song, or is there some work around to be able to do it through Rose Connect
Hello @agram4
If you add the Qobuz sound source to the playlist in the RoseConnect app, it is normal when the album you have created before comes out.
We don’t see the same problem on our side.
Can you take a video of the process of adding the sound source to the playlist and send it to me?
My e-mail address: eunseong96@citech.kr
