I have the following problem with my 250A.
When I listen to the radio, my background image is no longer visible across the entire display. Only the image on the right side, and the rest of the display, is grayed out.
When playing other options like Apple Music, everything is perfectly normal. Does anyone have an idea or is there a way to adjust this somewhere?
This is indeed the case with radios, I have reassembled this for my RS130.
I painstakingly saved my radio stations. Everything was great. Two hours later, it was all gone.
Sometimes less is more. I find the software overloaded. It’s really hard to keep track of things, and a lot of things don’t work properly. It’s a shame, really, because the device really knows how to play music.
I hope the picture feature works again soon. Thanks for the reply.
