RoseRadio: no longer allows uploading your own images
Since version 5.11.01.3 , or possibly an earlier version, it is no longer possible to assign custom images on any platform, including the device itself, the RoseOne app, the Rose Connect Premium app, Rose Connect Premium for Windows, and RoseOne for Windows.
This affects both existing radio stations and newly created ones.
Please restore this functionality as soon as possible.
The image selection is now limited to either a default image or a web search, which only returns very poor-quality images.
Even if an image is selected from the web search, only the default image is displayed after saving.
This functionality appears to be affected by a serious programming bug.
Why are features that were previously working reasonably well being made worse?
In the new version of RoseOne, which in my opinion is not an improvement, there is no longer any option to edit or customize radio stations in any way. The only available action is to delete them. Why was this implemented? It is a clear step backward.
Furthermore, this problem is not limited to RoseOne—it also affects all other input methods and applications.
Please correct these issues and restore the functionality that was available before. Thank you.
20260707_083433-1
20260707_083504.-2jpg
@MiKo
Thank you for sharing this issue.
We will fix it in the next RoseOne release.
Thank you, Rose_love, for the quick help.
However, it is now possible to select a custom image again, but the cropping mask is rectangular instead of square (Samsung S25).
Even though this doesn’t seem to have any effect (which is strange), the image is not copied into the database. The existing default image remains. The database does not save or overwrite it.
What I actually want to do is change an existing image. Creating a new entry for an already existing channel always places it at the end of the list. Since, unfortunately, no sorting function has been implemented for custom channels over the years, I would have to recreate all 50 of my channels just to restore my preferred order.
So please enable editing of existing channels and fix the image-saving bug. And please also in the Rose One PC Win App (only delete available).
And one more request, please, please: finally add a sorting function. :slight_smile:
Thank you, Rose_love.
@MiKo
  • After further reviewing your request, we will include it in the next release."
Thank you so much! It’s great that you’re implementing my suggestions. That’s excellent.
Everything is working just like before.
Please add a sorting function, too. Then RoseRadio would be the best solution out there, surpassing the other providers :slight_smile:
I believe in you!
@MiKo
I have forwarded your request to our software team to review the addition of a sorting feature for RoseRadio.
They will evaluate the request, and if it is feasible, they will add the sorting function in a future update.
