Rosetube failed
Rosetube failed on my 250. “Please restart rosetube for more stable operation” appears. Now it’s restarting the application for 30 minutes and that’s it! I’ve rebbotted and nothing…
Hello, is network connected properly?
Please check update version for rosetube.
RS250 > rosestore > rosetube > check if there’s update.
I checked the rose tube updates. All ok, but the problem persists in some videos. for example Tidal videos are always restarting and you can’t watch them.
@Ventura
Please check if it works after the factory reset.
