Rosetube login during travel
Hi there, I’m always using Rosetube to listen music but any chance that I can use my Macbook pro login to Rosetube when I’m travelling ? Thanks
You should be able to get it from the link below
https://ko.hifirose.com/support/download/905
@Eric_1428
It seems that Rose_love may have misunderstood your question.
If you are asking whether you can play RoseTube content through the RoseConnect PC app while traveling, the answer is no.
The RoseConnect PC app can only be used when it is connected to your Rose device on the same network. If you are traveling and your Rose device is located elsewhere, the RoseConnect PC app will not be able to communicate with the device because they are not on the same network.
Therefore, in this situation, RoseTube playback through the RoseConnect PC app is not supported.
