RoseTube stopped working on April 4th
RoseTube no longer works, it just says URL not found. This problem started on or around 4th of April 2025, has the ad-free license failed ?
Playlists just skip over all rosetube music, RoseTube cannot play anything.
@TomOOO
After entering the Rose Store on your Rose device, do you see the same symptoms even after deleting and reinstalling the RoseTube app?
Hi
Thank you for you prompt reply. I have reinstalled the roseTube app and that has fixed the problem. Thank you
