A quick query: I’m considering using an RS 130 via USB into an Innuos Phoenix USB reclocker, which runs into my DAVE dac. Are there any issues with such a set-up?
Thanks in advance.
Thanks in advance.
The RS130 can output via USB to an external device such as the Innuos Phoenix USB reclocker, and then feed your Chord DAVE DAC without any compatibility issues.
The RS130’s USB output supports high-resolution PCM and DSD, and the signal can be processed by the reclocker before reaching your DAC.
Many thanks for that.
