My RS 130 went into hiatus, and refuse to wake up. I’ve heard that a factory reset recovery file are avilable for download. Where can I access this? I suspect either Rose One or latest firmware update is the reason.
It happened to me on the Rs130. Impossible to get it out of standby
I unplugged it and then it restarted
I did that after the first time it happened (due to installation of Rose One) After uninstalling Rose One, I unplugged, then plugged back in and restarted after one hour or so. It was working perfect, and I received a firmware uptate, and still working. Then I installed Rose One again (first time since april) I couldn’t connect with the Rose app, and gave it up. After I went to bed it went automatically to hiatus, and has been there since…(Rose One is once again uninstalled)
If this issue continues to occur, we recommend contacting the distributor in the country where you purchased your RS130 and requesting that they inspect and, if necessary, repair the unit.
I interpret your answer that you don’t believe the factory reset file will work? I have an apointment with the dealer in a few days, and it was he that was suggesting the file, but not avilable to get it.
I believe it would be best to contact the distributor rather than the dealer from whom you purchased your RS130, as they may be better able to help resolve the issue.
Please contact the distributor first, and if you encounter any difficulties or the issue remains unresolved, let me know and I’ll do my best to assist you further.
Thank you for the reply
