I am using Roon running on a Mac Mini with the RS130 as the transport. The rose automatically mutes itself after every track and I have to manually unmute it. Roon and RS130 on stock settings.
Thanks for the help
Check the volume settings on the RS130. I once had the issue before. I don’t remember how I solved it but it was something to do with the RS130 volume settings.
Usb volume settings must be turned off
There are 2 sliders, set both to off
I fixed mine with the below as well. BUT mine were off. I had to turn on, then turn off and then reboot RS130. then it was fixed.
USB volume settings is set to off. I reset the unit a few times and appears to be working fine now. Thanks
