Rs 150 no sound
Trying to connect an audiolab 6000 via coax input on my rs150 and there is no sound
Tried the optical input also doesn’t work
Tried to connect another cd player ,same story.
What am i missing here?
What did i do wrong ,or is it possible that my unit is faulty ?
@David
Here are a few things to check.
  1. Did you set the output settings correctly in the input/output settings of your RS150?
  2. Did you set the input settings normally on your Audiolab 6000?
  3. When you connect the audiolab 6000 and RS150 with a different cable, does the sound not come out the same?
  4. When you connect the audiolab 6000 and RS150, does the signal sent from the RS150 to the audiolab 6000 get received?
  5. Is the volume of your RS150 loud enough? Please check if the sound does not come out even when the volume of the RS150 is increased.
