RS 150 unable to stream flac 24 bits 192.0 Khz
RS 150 not streaming at a sample rate of 192.0 khz, same song streamed on Iphone without issues, please review and provide solutions (streaming from Qobuz).
I could play Hurricane (Album Version) by Bob Dylan in Qobuz.
It’s flac 24bits 192.0 khz 2ch.
Would you explain more in detail about your situation?
  • What would it mean by ‘unable to stream’? No sound only with 192khz tracks?
    Or any error message pops up?
  • Are you using an external DAC? If so, what’s the model name of it?
  • Is the external DAC connected with USB? Coaxial? Optical?
RS 150 connected to NAD T778 receiver with coaxial, no sound when playing 96khz or 192khz, fine with 48khz sample rate tracks, TV screen shows output level of the track but no sound coming out of speakers.
I’m not sure what’s the input sampling frequency of NAD T778’s COAX IN.
If it’s limited to 96khz, you may hear no sound when playing 192khz tracks.
Try this >
  • RS150B > In/Out Settings > Menu of digital Outputs > PCM resampling frequency
    Start from 44.1khz and try one by one.
Direct Digital DAC-ESS Saber DAC with MQA Decoding available on all digital inputs.
i have this same problem with my hifirose 1310 going into av10. won’t play 192 files. no idea why not…everything should be able to and settings are correct. files “play” but no audio comes out
En coaxial la fréquence est forcement limitée ce qui ne sera pas le cas avec une liaison Usb
Gil
