Hi. I am having trouble with the XLR connections on my RS 150b DAC/streamer.
I connect the 150b, via XLR, into an Accuphase e- 380 integrated amp. Very often, usually, the left channel plays less loud and “softer“ sounding. I can also notice on the DB meters on the amp that the left channel is putting out less of a signal.
When I switch the cables at the back of the 150b from left to right, the problem moves to the other side. This is confirmation to me that the Rose XLR output is having the problem (not the amp).
I have tried different cables, and different inputs, and different brands of XLR connectors. When I connect the 150b to my amp using RCA cables, the signals are as they should be.
I have seen other posts on this forum commenting that these connectors and or connections can be problematic.
Please advise, is this an issue that should be looked at physically? The 150b is less than one year old, and I have noticed this problem for several months.
Please advise. Thank you.
