At times the light on my remote control will flicker and the streamer will change songs or go to the Home Screen. I’ve tried to pair the remote again and changed batteries. I don’t get it anyone have another idea to try? thanks. Thanks
Bonjour. J’ai le même soucis et la télécommande a déjà été changée. (Rs150b)
Gil
That does happen here too, mostly complete dimming of the volume. Remote seems possesed by ghosts…
Ghost in the Machine?
The remote control light may blink even when not in use.
The reason is because of BT communication.
Thank you for the reply and information.
Blair
This symptom indicates that when the BT radio wave becomes weak or interferes with the device and the BT remote control after pairing and use, the operation to search for the BT radio wave again is indicated by a blinking LED.
Therefore, this symptom is not a defect symptom but normal operation, and there is no significant difference in battery consumption as the device re-enters low-power mode after blinking the LED and searching for radio waves.
The more other devices around you that use 2.4GHz radio waves (microwave ovens, Wi-Fi 2.4GHz users, etc.)
Please note that this symptom may appear as the distance increases.
