please help me or I sell it, all the tracks I play through Qobuz stop before the end, why and how to fix it ?
Merci.
Merci.
I have had the same issue recently on my rs 130. While playing tracks on Qobuz the track either finishes early or is stuck in a buffer loop.
When I play tracks through Tidal there are no problems. The issue seems to be the Qobuz servers and not the RS 130.
I will be interested in @ROSEHAN response
Same issue on my RS150b and Qobuz app on my MacBook Pro
Just a quick note:
I’ve been playing music from Roon/Qobus for over five hours today and I haven’t had a single crash. Even in the days and weeks before, everything was fine.
So if it’s the Qobuz server, I’d also have crashes/errors with Roon, right???
That can’t be the problem.
Have a nice day
Does your location make a difference ? I am in the UK
The fault was yesterday, been playing Qobuz for 3hrs today, no issues as of yet
I’m in Germany…and maybe someone in the UK was on the internet cable.
There you go, everything is back to normal. Sometimes you just have to wait a bit (which I don’t like at all) and everything just has to work.
Have a nice rest of your Sunday
Many thanks Bonte, schonen tag
