RS 250 'forget' upsampling
I’m using the digital output and have set the digital upsampling to 192kHz. This setting will work for several days after confirming this setting. After a few days of usage (Tidal, Flac from hard disc and Radio Paradise stream) I see 96kHz on my DAC as input. I will go then to settings and confirm again. This will help again fo some days.
Can anybody help?
Best regards
KJM
@KJM
In order to give you an accurate answer to the issue, please answer the questions below.
  1. If you go to the Resampling setting when it is displayed as 96kHz while using it, is the setting unlocked? Or is it set to 192kHz??
  2. Can you tell me which model of DAC you are using and which of OPT/COAX or USB is connected?
  3. What is the cycle (frequency) that occurs?
when I see 96 kHz as input and go to the Rose settings I see 192 kHz. What do you mean with unlocked?
I push then the confirm button and after a short break everything is fine again.
I’m using coax to an Anthem AVM 60.
It happens approximately once per week.
Best regards
KJM
@KJM
We’ll see if someone similar to you experiences the same symptoms after setting up the device.
If the same symptom occurs, we will fix it.
