I am
Trying to Confirm the fuze specs to upgrade my RS-250.
Another user states he uses the following. Can I use the same fuze specs in the RS-250?
For the RS250A the fuse to buy is: T 3.15A 250V
I understand that the fuse to be replaced should be the same one used by the RS250A; In any case, I suggest that you consult with the people at Hifi Rose, what type of fuse your unit uses.
