RS 250 playback skips first second of each track
When playing from internal SSD on RS 250, first second of each track is not played. It is not only for the first track in a list, but each time a new track starts. Any solution for this?
@EBRU
This can usually be resolved by adjusting the PCM delay time on your RS250.
RS250–>Settings–>Audio settings–>PCM delay time
Although it is set to 500ms by default, it seems that the problem will be solved if you adjust it to about 1000~1500ms.
