Hi Rosehan,
Trying to figure out the best config using the 520 and 180. Would like to run the preamp outs to the 180 and use the 520 amp/speaker outputs to power additional speakers in another room.
I’ve had problems with running the 180 in bypass mode. Ideally would like to control volume from the 520. Assuming I can run the 520 in variable mode and also use the volume control on the 180.
Appreciate any feedback and best practices.
Thx
