Dear Rose Team!
Can I use RS 520 with Dynaudio Special Forty 6 ohm ?
By the tech.data RS 520 is Impendace 4 ohm / 8 ohm
Kind regards,
Oui bien sur. L’ampli peut gerer les 6 ohms sans problème
My RS-520 never had an issue driving Focal Vestia N4’s and they dip into the mid 2ohm range. It’s a super stable amplifier.
New user 520 it drives my 40s just fine. I would read that as between 4 ohm/8 ohm.
I have a pair of Wharfdale Elysian 4, 6 ohms, no problem at all
