RS130 and (Possible) Apple Music Issues
Hello, I’m writing to see if I can clear up some issues I’m having on my device.
  1. Whenever I use Apple Music and try to play a whole album from start to finish, it will play the first song but every song after that will be shuffled in some random order. I have tried all of the options and none of them will play the album in the correct order. This is something that has changed since the last update.
  2. I used to be able to tap on a song that was playing and add it to an existing playlist. When I attempt to do that now, it tells me the song has been added to the playlist, but when I check, it hasn’t been added.
Is there something I need to adjust or are these bugs? I appreciate any help and/or feedback. Thanks.
@DeepSouthDisco
Please check a few things.
  1. If you select the first song and the next song is shuffled, check if the shuffle function is activated as shown in the video below.
    www.youtube.com/watch?v=OAwcpf63Z8I
  2. The video below shows how to create a playlist and how to add music to the playlist.
    www.youtube.com/watch?v=MoR-48HhRRg
Thanks for the reply. The unit will not, under ANY circumstances add a song to an existing playlist. It says it’s added but when you check, it isn’t there.
