I can’t select any digital out apart from USB and HDMI. I have AES and I2S connected but all options are greyed out on display. Same on Rose HiFi app.
- How is RS130–>Settings → System Settings → Audio Firmware Version Information displayed?
- Even if you reboot RS130, won’t the input/output settings change the same?
- Even if you factory reset RS130, can’t the input/output settings be changed?
RS130–>Settings–>System settings–>Factory reset - If you have tried all of the above methods and they do not work, you may need to contact the distributor in the country where you purchased the RS130 for repair.
Since this issue is not recognized by XMOS, it does not seem to be resolved with a software update.
