RS130 Clocking issue on AES/Coax/Optical outputs
It seems that RS130 is not sending clock at all times via AES/Coax/Optical outs and it takes time for DAC to sync/re-sync to lock the signal.
I am getting 15-20 seconds of silence on those outputs when playing songs or albums with different bit/sample rate or if playback is paused and then restarted.
This is not the case with USB output.
Problem is present on I2S as well.
I experienced the same… Added the Fiber Hub and switched to USB to avoid the lock delay.
This is unfinished product on so many levels.
