My friend has just bought a set of RS130, but it cannot recognized its Accuphase Dac DC950. At the very beginning it was no problem at all. But after some weeks of use, the screen always appear as below… He has tried everway, like re-setting up again, disconnecting all cables etc… but still fail to work properly. Moreover the output setting of coaxial/AES/EBU can’t be chosen too. It just works on the HDMI & USB. Please let me know how to tackle the problem, thanks!
@Allan
- The picture you uploaded is a screen that needs to be initialized to appear, but does that mean that while using the RS130, it always skips like the picture you uploaded?
- When connecting coaxial/AES/EBU, does your DAC indicate that it is connected?
- Have you tried connecting with another cable when using coaxial/AES/EBU?
- If all of the above fails, you may need to contact the distributor from which you purchased the RS130 to check and repair it.
eng.hifirose.com/Distributors
Got it thanks! I will advise him to give it a check in the dealer.
