After updating my RS130 to SW 5.9 and XMOS 3152, my RS130 fails to scan audio files from the internal SSD. DB Initialization shows 0 scanned tracks, even though the files are playable. Rebooting doesn’t fix it. Please advise or confirm if this is a known issue.
Here are a few things to check:
- Does your RS130 not recognize your SSD after disconnecting it from the RS130 and reconnecting it?
- Do you have trouble scanning your SSD after factory resetting your RS130?
- Does the songs scanned from your SSD show as 0 in the media library on your RS130?
RS130–>Settings–>System settings–>Media Library
