RS130 is stereo only?
Is it true all HiFI Rose products are Stereo Only even on the HDMI port?
The RS130 sends both audio and video, however, you have to switch to HDMI output. Video is sent along with HDMI when on another outputs.
I would also like the answer to getting MCH files to play, for now I am using my OPPO for this.
Please answer: can multichannel music be bitstreamed to my preamp via the HDMI port?
@joyofmvid
Rose devices do not support multichannel music.
@joyofmvid another reason to use Roon > Rose. Roon streams MC to my receiver over HDMI up to 7.1 PCM.
What does the HDMI Pass Through do, how does it work @ROSEHAN?
@HMANAZ
It bypasses HD audio formats such as surround sound sources to audio receiver through HDMI without decoding.
Do you mean, RS130 “bitstreams” 5.2 & 5.2.4 music on HDMI port. If so, that would be perfect for me.
EDIT on Jan 20, 2025:
I found thhe answer at Playing .mkv files from an rs130 - #7 by HMANAZ
RS130 Bitstream’s 5.1 & 5.1.4 audio
I’m now a happy puppy! :grinning:
So @ROSEHAN, Rose devices do support multichannel? Now I am confused, @joyofmvid that was my message. I am seeing conflicting info, still unable to get pass-through to work. I have MKV multichannel files I wish to pass through to my oppo players HDMI in. If I play them from Rose, I only get Stereo over HDMI with pass-through enabled. If I play them from my Oppo (terrible UI) I get MCH.
@HMANAZ
I don’t expect RS130 to decode multichannel audio but does the RS130 passthrough (i.e., bitstream) 5.1 and 5.2.4 audio to the receiver? If no, then what does HDMI Passthrough do?
Re: Output Settings —> HDMI —> HDMI Passthrough = ON
The manual states:
17375794108384759582178381540041
Thus, the manual states the RS130 bitstreams 5.1 and 5.2.4 audio to the receiver.
@ROSEHAN Please confirm surround sound and 3D sound is bitstreamed - only your confirmation will stop the confusion in various posts!
@ROSEHAN @joyofmvid
Here is my connection chain and experience trying to play MCH files from the rose.
MKV MCH file on Rose → HDMI out → Oppo 203 HDMI in → ONLY PLAYS STEREO (with HDMI Pass-through enabled)
MKV MCH File on Oppo 203 → Plays MCH
Can someone please explain how the passthrough should work to
Do this :point_up_2:
Rosehan et al,
Has any additional thought been given as to whether and when the RS 130 can be upgraded or programmed to use the HDMI pass through to send un-decoded multichannel Atmos music to an Atmos capable AV processor?
@Eleven
At present, the RS130 is designed as a two-channel high-end network transport and does not support HDMI passthrough of un-decoded multichannel Atmos streams to an AV processor.
Its HDMI output is intended for stereo PCM/DSD digital audio (and GUI output), rather than multichannel bitstream formats.
We understand that support for native Atmos passthrough would be of interest for users with Atmos-capable processors. However, implementing this feature would require both software development and hardware validation, and it is not currently on the RS130’s feature set.
Then change the “HDMI Passthrough” setting’s description to describe what this setting really does or remove the “HDMI Passthrough” setting entirely since there’s no passthrough functionality.
