RS130 network/APP connection loss
During playing for instance an Qobuz Album or Radio my RS130 stops playing.
Sometimes it came back, often loss of LAN and same time loss connection to RoseApp.
I changed SFP FC modules, no help.
@Christian
Please check a few things.
  1. When Qobuz and radio playback stops on RS130, does buffering occur and then automatically resume playing?
  2. Does the same stopping phenomenon occur when connected via Wi-Fi instead of Lan?
  3. Does the music stop playing when you play it on a streaming app other than Qobuz or radio?
  4. Does the same problem persist even if you factory reset your RS130?
  5. Does the same symptom appear even if you delete and reinstall your RoseConnect app?
Maybe the issue is solved now, i have to observe a bit more the next days:
What i dit is firmware reset.
Changed SFP modules and FC cable, but in the very end:
RS130 got manually, solid IP-adress out of DHCP scope from my AVM cable box / router.
The last 3h playing time no interrupts anymore, RoseApp fine.
Thank you very much for your point list 1. … 5.
I will preserve this for further needs and come back here.
RS130 stable on network, now.
Due to manually IP-adress out of DHCP scope all fine.
No losses with app anymore.
