Just now I followed instructions to update my RS130 to the last version (5.9). When done there was a screen saying that I should also update my streaming app to the last version, so I uninstalled and reinstalled Rose Connect Premium on my Android phone. But now – even though the RS130’s network indicator is on and it is seen by the Fing network scanner – the RS130 is no longer seen by the Rose Connect Premium app. Did I do something wrong?
Please answer some questions.
- Is your Rose device not connected to the RoseConnect app?
- Is your Rose device not found in your RoseConnect app?
- Is your Rose device registered?
Rose device–>Settings–>Device management–>Register
You must click Register in the picture below to register.
- Are your Rose device and Android phone connected to the same network?
Rose device—>Settings—>System Info—> IP address shown in IP Address and Wi-Fi IP connected to your phone Up to two points must be same.
Example) Correct
Ethernet IP Address: 192.168.4.44
Android phone IP Address: 192.168.4.33
Example) Wrong
Android phone IP Address: 192.168.6.33
Thanks for this. However, this morning I tried again, and I was able to connect again, so all is good
