My ~2 month old RS130 has now started to constantly stop playback. Sometimes it will play for 10-15 minutes fine and then stop, other times it won’t play at all right after power up. I use Roon and get a “Too many failures. Stopping playback” error after it skips over a handful of tracks. At this point it will not play anymore unless it is rebooted. This does not seem to be a Roon issue as using Tidal or Quobuz direct on the RS130 does the same thing. If I reboot the RS130 it will again work for a short period and then is stuck once again. Absolutely maddening! And unacceptable at this price point!
I use a wired ETH connection, but also tried WiFi with the exact same results. I have gone through a full factory reset and no change. I tried leaving it unplugged from power for a week to make sure all caps/energy storage was fully dissipated, again same crap.
I swapped in a Bluesound Node as a sanity check to see if it could be something else in the system, using the same ETH connection, DAC, coax cable, etc. Works flawlessly. So this is definitely an issue with RS130.
Help!!!
