RS130 Remote IR Codes?
I am looking for the IR remote codes for the remote included with the RS130.
I want to use them with an Unfolded Circle Remote 3. Sadly, the Remote 3 does not recognize the output of the remote to learn the codes. I have run into this issue with a different remote and the solution was simply to upload the Pronto codes.
The rs130 is Bluetooth so no possibility to learn ir codes
The remote that came with my RS130 transmits IR commands and the RS130 unit receives them.
If I cover the front of the remote or front of the RS130, the command is not received by the RS130. If I fire the remote into a learning remote, the learning remote will learn the code.
Unfortunately, the Unfolded Circle remote does not interpret the code correctly and therefore I am seeking either the Pronto or equivalent hex command codes.
IR and Bluetooth on the RS130
If you’ve a Harmony in your fundus, then you can add here the RS130 directly from logitech and try then to learn it from there.
Obviously many times asked: Rose doesn’t publishs their used web api or ha integration.
This should be the way in using the unfolded with Rose devices.
