RS130 screen flicker after update OTA 5.7
had my RS130 for about 6 months now, worked without a hitch. really enjoyed the change it provided my system. shortly after updating to 5.7, problems started. it boots fine, but when I start applications (music or radio), shortly after music starts the screen flickers.
some video clips:
https://1drv.ms/v/s!AvgkGDrHhZy2gu0W6ZWW_DWzX5MWIA?e=RDiciB
https://1drv.ms/v/s!AvgkGDrHhZy2gu0VuYQIZzo57jQYVw?e=D4mzf9
I did have the same with my 130 in the past.
Now I use this filter and it never happened again
https://amzn.eu/d/gG3LheB
@fhindi
If the same symptom appears even after rebooting the RS130, contact the distributor in the country where you purchased the RS130 and request LCD repair.
It isn’t the LCD
They changed the LCD in my RS130 and it still did flicker sometimes
After applying the filter it didn’t happen again so far
thanks Bitspeed. any understanding of why the high frequency filter affects the screen?
Also, how long have you been using the filter? thanks again for your help!
I guess it keeps away electrical noise from the power circuit
Now using it for 4 months or more with no more flickering issues
