I own Weiss 204 and playback designs DACs, and my friend has Weiss 501 (Original version, not 4 Channel) and we compared RS130 / RD160 via USB SFP, to RS130 / Weiss 501 via USB, we both found that RD160 was better than Weiss 501.
WOW! Better than Weiss 501 - that’s impressive
What transceiver module do you use
How do you connect from RS130 to RD160?
If I have an RSA720, what is the recommended connection?
I like Finisar FTLX1475D3BTL with Corning OS2 Single Mode the most.
Thanks for your quick response.
As you mentioned, you connect Router SFP > RS130 Ethernet port and RS130 USB SFP port > RD160 USB SFP
Since RS130 has only one SFP USB port, what’s the best way to connect both the RD160 DAC & RSA720 Hub to the RS130 Streamer - any recommendation?
Like I stated above, there is no solution to connect both RSA720 and RD160 via SFP at the same time. I only can use RSA720 as a regular USB Hub.
I’m sad to here this. AFAIK, the RSA720 USB SFP > RS130 USB SFP improved the audio sound. That’s why I ask.
So, do you think I’ll still get improved audio sound with the following RSA720 connection (or should I just leave the RS130 access my Synology NAS)?
RSA720 USB 3.0 > RS130 USB 3.0 and RS130 USB SFP to RD160 USB SFP
Yes. That is exactly how I use it.
Hi @Yu3319
Just wonder what equipments you are plugging into the RSA720 ?
With the RD160, I found the RSA720 lost its purpose as there is no way to benefit from its fibre capability. Although it is a well-built product, I am considering selling it.
Say the RSA780 CD drive, does it sound better via the USB hub than directly into the RS130 ?
Yeah totally. Today Hifi Huff reviewed on YouTube and said it’s definitely same level as Weiss501
I use RSA720 as a regular USB hub: connect my 10TB of HDD to RSA 720 via USB. Otherwise, there is no use for RSA720.
Hifi Huff came to the same conclusion as RD 160 is on the same level as Weiss 501. However, he didn’t use SFP connection. When I used SFP connection, I felt that RD160 is a little better than Weiss501.
Yes. The RSA720 has not much use with the RD160 in place. I cling to sell it than use it as a “midway” between my CD drive and the RS130.
So, as I suspected, Hifi Huff didn’t use SFP connection, which among many of us agreed that SFP improves SQ. If USB is on par with the Weiss 501, I2S should be a bit better. And SFP the best.
YES WHAT A FOOL !! HE DIDnt Use the best connection . If that’s his opinion with USB, us SFP users are experiencing above Weiss 501 as many have reported !
He has too many toys to play with, and a lot queuing up already.
Lol … maybe somebody smarter will be able to make another video and explain better the SFP advantage
Agree about RSA720 - I want to sell mine
A simple test that demonstrates that SFP modules have different performances:
Ah, Alpha Audio, people who make Hans Buttheadszen look almost intelligent!
As with anything posted there the, the “test” demonstrates that they are a) crooks, and b) not very intelligent ones at that.
HI all!!
The optical fiber between Rs130 — Rd160 Dac is not working for me, what could be the problem?
internet — switch. OK. Finisar FTLX1475D3BTL + Corning SMF-28 Ultra + Finisar FTLX1475D3BTL
switch — RS130 OK. Finisar FTLX1475D3BTL + Corning SMF-28 Ultra + Finisar FTLX1475D3BTL
RS130 — Rd160. Not OK!!! Finisar FTLX1475D3BTL + Corning SMF-28 Ultra + Finisar FTLX1475D3BTL RS130 — Rd160 OK factory sfp cabel
THX
I’m using the same SFP modules but with 2m OM1 LC to LC UPC Duplex Corning Fiber Optic Cable MultiMode 62.5/125 OFNR Rated, Orange between the 130 and 160 SFP modules. Works great.
- According to the datasheet FTLX1475D3BTL has Wavelength 1310 nm and is used with Fiber Type Singlemode. So it can’t work with Multimode fiber.
[https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/5731/FTLX1475D3BTL.pdf] - According to moderator rosehan, the SFP port for the RS130 network is 1Gb and does not support 10Gb modules, so the FTLX1475D3BTL should not work.
- For the RS130 to RD160 connection, several forum members use a DAC cable, Amphenol SF-SFPP2EPASS-002.
