RS130 SFP network port (SFP or SFP+)
I have a SFP+ AOC that I want to use with the RS130. Can The SFP network port on the Rs130 accept SFP and SFP+ modules?
Thanks.
@duffer5
I’m sorry to tell you that, RS130 does not support SFP+ modules.
Thank you for the reply. I figured it out. I would suggest that under the specs you state that the port is only SFP. I understand that it says up to 1gb but for people not familiar with SFP this could be confusing. Simply state SFP only.
