Hi ALL
I have now an RS150 and considerung to upgrade to an RS130.
The following is existing and working without issues:
I do rarely use the Rose Software and Apps and if, only for playing or demoing around. Normally I simply use Roon.
An external DAC (Soulution) is attached to the RS150 with USB and maybe I will buy a Mola Mola Tambaqui DAC.
Here are my quesitons:
- Will everything work the same way as it does now with Roon?
- Is the Mola Mola Tambaqui fully supported and working for I2S and/or USB connection?
- Fiber Optic USB - can I attach a USB DAC directly to the Fiber Optical USB? (According the product site, USB Fibre is only to be used for Storage or the HUB, therefore useless with a direct DAC connection, correct?)
- Are there open issues with the current FW regarding the way, I use the Rose as a Streamer?
(I don’t have any issues with the RS150 with the latest OTS FW).
It’s difficult to lend an RS130 from a dealer nearby to test it all by myself.
Your answers based on your experience (even just partial ones) are very welcome.
Adrian
