Hello Hifi Rose @ROSEHAN
Can you please clarify which screen is on the RS130. The marketing webpage says that it is IPS and TFT which technically can not be the case.
The included user manual lists the screen as both TFT and IPS as well.
!IPS kan ook TFT zijn, zie dit artikel
De 130 heeft een zeer grote kijkhoek, dat heb ik met die van mij getest.
Dus zeker IPS
Thank you for the info. Also the TFT info is in the on unit startup tutorial.
The unit startup tutorial part needs to be modified.
Please understand our mistake. We will fix it quickly.
