RS130 using I2S port "Pop" sound
I am the new user for RS130 with Holo Audio Cyan2 DAC. When I use i2S as the transfer media, a Big Pop sound will happen. If I use USB, no such problem happened. How can I solve it?
Same combo be me, works very well without issues.
My RS130 is in I2s A-Mode.
When do you hear the pop sound…?
Try to change the cable, after shutting down both units completely.
But also, good to hear USB is working too with this combo.
Once the first time I choose the first song, Pop sound will happen when using I2S port. Then no pop sound occur for the other songs. My local dealer of the DAC said it is the design problem from RS130. I don’t know how solve the pop sound.
@juno2889
  1. When you connect i2S, does pop sound only occur from certain music sources? Or does it always happen on every sound source you play for the first time?
  2. Do you experience the same symptoms even if you use a different i2S cable?
I tried every sound source would also have Pop sound as well at first time. I only use Apple Music and Tidal
I have not try other HDMI cable. I want to try fiber type HDMI cable but seem not work for I2S. I will find some other HDMI cable to test
My cable is Audioquest HDMI cable
