Hi There,
Any reason why COAX, AES/EBU, and I2S won’t output any signal? Yes, outputs are activated, unit firmware updated, factory reset done. HDMI and USB seems to be working fine though.
Tested with Eversolo Z10 (COAX, AES/EBU, and I2S), Marantz AV8802A (COAX) and some small FOSI dac on coax.
Maybe I’m missing something silly here or maybe the unit is faulty?
