Setup the RS130 Friday and now it won’t power on. NO screen, I can here a clicking sound if I try to power it up. The reset button doesn’t appear to do anything, it’s just a loose button with no resistance. Any idea?
Hello
Please check a few things.
- Is the RS130 power cable connected properly?
- Does a relay sound come out when you press the power button on your RS130?
- If you hear relay sound but nothing happens on the screen, you will likely need to contact the distributor in the country where you purchased the RS130 for repair.
