RS150 could play native DSD 64 and down (converted to PCM) but not play native DSD 128 and up at all while software volume control on but normal when software volume control off.
It is simple connection thro’ analogy xlr out to amp.
Do you mean that when software volume control is “on” native DSD128 file plays? and when “off” DSD128 file can not be played?
DSD related output settings can be set in In/Out settings.
If you select In/Out setting->OUTPUT->digital output setting (gear), you can select DSD Mode.
In the case of ‘DSD over PCM’, if the DAC supports DSD, up to DSD64 can be transmitted to DOP.
If you use ‘DSD to PCM’, you can change up to DSD128 to PCM.
I mean that when software volume control is “on” native DAD 128 and highter than 128 file could not play but software volume control is “off”, all native files could play.
Hello @Aaron
That’s normal. Native DSD cannot be played when software volume control is “on”
