Ver 3.8 SW Update Notice
- Update date: 2021/04/29 (Thursday) 05:00 PM
- Update Method: Settings → System Information → Click “Update” and update the system
- Updated version: Ver 3.8 (Rose OS 3.8.04)
- RoseConnectPremium for Android : Ver 3.8.04.1
- RoseConnectPremium for iOS : Ver 3.4.4
- Applied Model: RS150/RS201/RS250
*Updates:
- Rose Tube > Add Youtube Player
- You can watch Youtube real-time videos.
- You can set up Youtube Player ON/OFF in rose tube settings, and login with your Youtube account when you turn it on.
- View and play the playlist, subscription list, history of your login account in Rose Connect (Android)
- Added SACD ISO playback and ripping function.
- Added Rose FM Tuner
- Added the tethering function.
- Added the Video Genres/Favorites Tab
- Detailed genre settings can be edited and saved through the meta-information of RoseConnect.
- Added Qobuz Gapless Function
- Modified RS201 EQ Scenario
- Custom Mode selection popup will be displayed when you change the detailed settings
- Settings > Add Model Tabs to System Information
- System Stabilization
- Modified the status that the clock UI could not be changed when entering additional favorite buttons with BT RCU.
- Modified the status in which the loading image would not disappear from the Tidal login page
*Cautions
- Do not turn off the power during SW update.
- After the SW update, the audio system will be updated, so be sure to proceed when a pop-up occurs. (1~2 times)
