Ver 3.8 SW Update Notice
Update date: 2021/08/12 (Thursday) 18:00 (GMT +9)
Update method : Settings → System information → Click “Update” and update the system
Updated version: Ver 3.8 (Rose OS 3.8.13)
RoseConnectPremium for Android : Ver 3.8.13.4
Applied model: RS150/RS201/RS250
Update:
- Added USB/SSD power activation menu in standby mode (Settings > System Settings)
- OFF, ON, Auto setting available
[RS201]- When using Off mode, the USB2.0 port is disabled, but the 5.0V power of the USB2.0 port is not off.
 - When using the Auto mode, if a USB device is connected, the USB port and SSD are maintained, and if no device is connected, it is disabled.
[RS250] - When using the Auto mode, if a USB device is connected, the USB port and SSD are maintained, and if no device is connected, it is disabled.
[RS150] - When using Off mode, the USB2.0 port is disabled, but the 5.0V power of the USB2.0 port is not off.
Caution. If you are using a WIFI dongle, the network connection is disconnected when Off.
Added Daylight Saving Time function (Settings > Region & Time)
Added Play/volume information enlargement function (Settings > Display)
- Play information: Enlarged view, Basic, Small view settings available
 - Volume information: Enlarged view, basic settings available
- Add/change screen brightness function (Settings > Display)
- Added AOD screen brightness control function
 - When LCD brightness is “0”, it is darker than previous status (RS201, RS250)
- Language setting
- Added Dutch/Spanish language
Added DLNA/Airplay service ON/OFF function
Rose FM
- Subdivision into city units when changing countries (USA)
- CD
- When a CD drive is connected, the CD icon is displayed on the top of the home area.
 - Added CD eject function when touching home CD icon
 - CD DB Data such as (ThumNail, Album, Artist, Title, Running Time, etc.) expansion (CD ThumNail stabilization)
 - Fixed certain CD ripping errors
- Added input/output setting detailed menu
- Added RX channel information input setting menu (RS250)
 - Added Balance Setting function (RS201)
 - Added Optical level setting function (RS201)
- System Stabilization
Improved loading status when playing Rose Tube
Fixed an error when entering special characters, spaces, or Korean in SMB ID
Fixed the problem that certain ISO files do not play
Improved the pop noise status when playing DSD sound after setting DSD to PCM
Fixed the problem that the sound is not output when standby mode ON > OFF while playing Roon music
Improved WAV, WMA music file information display function
Cautions -
- Do not turn off the power during SW update.
 - After the SW update, the audio system will be updated, so be sure to proceed when a pop-up occurs. (1~2 times)
