the quality of Tidal videos are presented blurred and grainy over the TV connected via HDMI. The HDMI settings are at maximum and the same video played through Rosetube is much better.
The problem is not with Tidal itself, in fact by playing that video from my Macbook using the same HDMI cable is very much crisp.
Seems like the problem is withiny the RS150 device and the decoding of the Tidal video.
I have done the factory reset but no luck.
Any suggestions or expected updates to fix the issue?
