When the RS150b is used as a DAC, I would like to be able to see on the dispaly the sample rate and bit depth of the audio track being played (e.g. 96 kHz - 24 bit). Is there any possibility in the future to have this function?
Currently, the only device that displays sample rate and bit rate when using a Rose device as a DAC is the RS520.
Our software team will check and let you know if the feature can be added to the remaining devices.
Thank you very much for your quick answer.
If this feature will be added to other devices as well, that would be great!
Greetings.
Sorry to answer like this, but the circuit structure of RS150b is different from RS520, so modification is not possible.
Thanks anyway for checking this feature.
Regards.
