RS150B Pre-out Level Setting help
Hello. I am using RS150B to connect Atoll IN300 Integrated amp via unbalanced cable (RCA). Could you please advise me which Pre-out Level Setting should I choose?
Thanks.
Hello, try 1900-2200. What do you like more
Hello, Denis, U meaned “6000mV (Unbalanced 1900mV)”?
Yes, (6000)-1900, but you can also (6500)-2200 try two options.
2 volts this is 2000mV IS TYPICAL if you have to turn volume up past 10 o clock then set to 3v 3000mV. WHEN DOING THIS TURN AMP VOLUME CONTROL to a minimum setting first . then try it . slowly turn amp volume control to you preference look at your spec of amplifier sensitivity phono rca are about these valued iF XLR ABOUT DOUBLE THIS
I use 6000mV (Unbalanced 1900mV) with XLR but it all depends on the input sensitivity from your amplifier.
