Hi, does anyone know what level I should set on the Rose for the Michi X5 (balanced) please?
Google says this for X5 Line level inputs (XLR): 580 mV
So can I set to 1000mV or needs to be lower? Thanks
INPUT OVERLOAD
Line Level Inputs (RCA): 12.5V
Line Level Inputs (XLR): 12.5V
Phono Input (MM): 197mV
Phono Input (MC): 19mV
Here is the maximum accepted by the Michi. It is visible on the official website
So 4 or 6 volts seems quite reasonable
Thank you for your reply. So to clarify, you say ‘4 or 6 volts’. Is that 4000mV or 6000mV as shown on the Rose settings? Apologies if dumb question.
Hello @Ataripower,
Yes, yes, yes…
Were you just getting chalk when you were learning about this topic at school???
You can also google it.
1 liter of beer is 1000 ml of flat beer.
1 volt is 1000 mV
1 ton has 1000 kg…1m has 10 dm and 1000 mm
OUI
4000 /6000 mv To try according to your preferences
Lol, yes school was not my favorite time, luckily I had other skills to get by with
