My RS150B has started with my screen mis-alinged. The clock icon is cut and the top line is shifted across. So, for example selecting s\Settings opens RoseStore.
How can I fix this problem amd why does it happen?
Thanks,
Steve
ps cycling the power reset it, but still want to report
Did you restart machine by disconnecting from mains?
I used the mains switch. It reset fine. Just surpised it happened. I’m not sure I can reproduce the bug.
Thanks,
Steve
This is Android in it’s glory
